Do you mean the actual bulbs in the speedo cluster or some add in lighting for accent?
91GL Green Auto DD There ain't no rest for the wicked
until we close our eyes for good. I will sleep when I die!
Discuss custom Festiva or Aspire audio systems, GPS, car alarms, etc
I intend to place an angled courtesy bulb at each corner just under the dash. It will be wired into the same circuit as the ceiling lamp. I have found that the older style housings on cars in the late 70s and early 80s work best. If they have a plastic housing, they will have two wires. (one for ground). Otherwise, just bolt the metal housing to a good ground. Good luck.
