Last night my cousin and I started fabbing up the hitch to tow JTfest's ride from Wisconsin to Iowa. We're about 400 miles apart from one another. I'll add some pics tonite or tomorrow, but narrate our progress, now.
The two types of Festy receivers that I have seen either have a flat long stock for side to side, frame rail to frame rail and a small flat stock to mount to bumper. Or the other has the flat long stock for side to side, frame rail to frame rail but another piece of flat stock that goes towards the front of the car where it is fastened to a "T" with another piece of flat stock that is mounted, side to side, with bolts through the spare tire tub.
My Dad was hauling 3 misc junk receivers to the Festiva Funny Farm the other day, along with some pretty stout angle iron. I picked the one I thought would work. One long flat bar to go from frame rail to frame rail and then a short flat bar to mount onto the bumper.
At this point I will tell you, I do no want to fasten to our stock heavy duty rear bumper. I choose to go rail to rail, but reinforce with angle iron. The flat stock, I'm pretty sure is strong enough that it won't flex much, front to back. I don't think it is thick enough, though, to keep from moving up and down. That is where the angle iron will be welded in, either below the receiver's flat stock then part of the angle iron pointed down or maybe I'll triangulate the angle iron, essentially, boxing it in. I'm open to opinions on on which would be stronger.
Best side view drawing I can do for now.
________ Receiver
________ Angle Iron
or
__ Receiver
V Angle iron
Anyways, hopefully you understand what I was trying to say.
The tie downs themselves are pretty heavy duty and appear to be stamped or pressed with a rolled edge to increase rigidity. The tie downs in the rear are fastened with one bolt, and tack welded at he top and through the center onto the unibody. The nut is part of a box system the wraps around the unibody rail and spot welded....least I think so, but could not see the welds. I saw no reason to break those welds, but, instead, had my cuz weld as much of the tie down to the unibody as possible and add welds to the "nutbox" ...LOL...that just sounds funny!
Then I took a piece of cardboard and made a template that would fit inside the rolled egdes of the tie down. Cuz then welded up some 1/4 " thick plate into a large L-bracket. Then we traced the template onto the L-bracket and cut the metal to shape. Drilled a hole for the existing bolt, which I later bought a bolt 1/2" longer to compensate for additional thickness, and a larger hole to add a new bolt, washer, lock washer and nut, that will fasten through one of the angled oval holes. Now the receiver bracket is fastened by 2 bolts and inside the rolled edges for a solid mount.
Next, we will cut the receiver's flat stock to width and weld to the bottom side of the L-brackets. Then remove the short flat stock designed to mount on the bumper, for a heavy duty tow package....least heavy duty enough to tow a Festiva....Festiva-style!
I'm suppose to help my cuz finish the set up in the next couple days, so I will snap photos and post them to clarify my rambling nonsense!
________ Receiver
________ Angle Iron
or
__ Receiver
V Angle iron
