180km/h speedo installed
  • 180km/h speedo installed
    Just installed the tach cluster I picked up on e-bay. It's white lettered and the speedo goes up to 180 km/h. I did have to switch the circuit board for one from a US tach cluster and the only glitch I see is that when the check engine light comes on it will look like I have a door left open
    I'll get some pictures up in the next couple of days.
    On another note... I want to change the color of the needles in the cluster from orange to white. What paint would work best?
    Cheers
    Ian
    pics...
    93-1.6l
    f.s.- fms bodykit.
      Cluster
      I just received two 110mph clusters from England, and they work just fine when you change the printed board on the back. I did have to enlarge the slots for the two diodes on the housing, they're in different holes on the English version.
      Cat
      Chuck
      91 GL -Ol' Rusty
      93 GL - Lil Red
      91 L - Tweetystiva
        One time I painted my needles in a speedo I used regular spray paint on them. (removed needles, they pull off)
        93 GL modyfied!!!
        :fish:
          Thats what i had to do and i also have a "door open" light for my check engine, it's so much nicer having a tach cluster in KPH :lol:
            I wonder where & what mine came off of? I didn't have to change anything...
            It was an FMS ebay buy. The only issue with it is that it doesn't have a light for when my highbeams are on...
            Mon arme a moi, c'est un stylo.
              That's an early cluster. I believe the 90 and up had the white faces.
              Cat
              Chuck
              91 GL -Ol' Rusty
              93 GL - Lil Red
              91 L - Tweetystiva
                Cat
                it's in KPH and KPH tach clusters were not available in Canada
                it's possible the earlier prides had the same wiring?
                  I think it is from the early years. A couple of things I noticed... the speedo only goes up to 170 kph and the the trip odometer button is closer the the center of the cluster than on the white lettered version. My guess is Kofkof's cluster is an earlier cluster from either the Philipines or Japan.
                  Ian
                    ^^I'm not so sure about that because i got a white faced 170 kph tach cluster with my red car
                    this is the only pic i got and since the speedo didn't read properly i gave it to a local festiva owner
                      Sleeper and I exchanged PMs about that white faced cluster you have there... I think he said something about someone putting a MPH gear driver thinggy in it
                      89SX funtop! Fully loaded!
                      RIP 90LX
                        ^^Ya i beleive it was a speedo gear from 85mph tach cluster
                          Update with photo
                          Hey all, here's the photo of the 180 km/h speedo installed.
                          As mentioned earlier I did have to change the circuit board and I have also upgraded the light thingy from two bulbs to four (the one that comes on the non-tach cluster).
                          Cheers
                          Ian
                            looks good! did you calibrate the odo?
                            RIP 90LX
                              I've changed clusters about 4 or 5 times now and haven't bothered to change the odometer. I've also lost track of how many kilometers are on the car anyway
                              Ian
