Installing an aftermarket tach on a car without one
  • Installing an aftermarket tach on a car without one
    I have a 1994 Aspire and I want to install a tach. How would I do that? There isnt one on it already so would it have something hooked to the engine or is it through the ECU?
    This is the one Im looking at
    http://store.summitracing.com/partde...r&N=4294815748 4294905534&part=SUM-G2905&autoview=sku&Ntk=KeywordSearch
    Right near the bottom of that page you'll see "Instructions" and the link opens this document:
    www.dantheoilman.com
    Go ahead and ask me why
      Tach Install
      So if you know how to pull you cluster it's no problem. In an aspire you pull that lilttle black piece of trim , it just snaps out. Then there is 2 or 4 phillips
      screws to undo. Grab the cluster and pull it towards the drivers side. Then you will be able to reach you hand aroud and undo the spedo cable. Just squeese the two fat ends and pull. Then undo the electrical harness. Take a close looke at the harness. there will be an empty spot where a wire goes in
      but no electrode is present on the plug. That is your tach wire. Splice into your tach and your good to go.
      1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
      B8-ME Swap COMPLETED.
        I got the tach. I took off the cluster but I dont see how it would work. It says to connect it to the ignition coil. Anyone care to help me?
          Is the wiring different between the Festive and Aspire? I have a 94 Aspire if it makes a difference.
            if you have a wiring diagram of the aspire, you should see a wire that is labled "tach Sig" this is the wire you have to splice into. that OR find the ground side of the IGN modual and tap into that to get a signal. I'd try the first one though seeing that all aspires used the same dash harness even if it didn't come w/ a tach stock.
              I found it. Its the yellow wire going in to the dist.
                i think this is the correct pinout
                and wiring diagram
                -rev till the valves float grab second and haul ass-
                  damn i was hoping for a chance to show off my new aspire evtm....
                  Jesus is on my dashboard, But the Devil is under my hood
                  1988 ford festiva...in limbo, apartments suck
                  1995 Ford Aspire...in limbo, wow i need a garage
                  2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
                    is it possible to put a tach on a 93 festiva?
                    Stock is not an option!
                      it's possible to put a tach on anything with an engine.
                        i kno its an old thread but...
                        how do i hook up the tacho to the head lights/dash lights?
                        its a 98 festiva
                        thanks in advance
                        matt
                        1998 Festiva:
                        Sony Xplod Head-Unit,
                        12" 500W Clarion Sub,
                        Motor Sport tacho,
                        More to come!
                          I'm assuming you want to hook up the illumination for the tach to light up with the rest of tyhe dash right? well if thats the case i would find the wire running off the headlight switch that is hot when you turn the knob to the parking light setting. tap into that for the juice and run your ground for the gauge. wish i could be more specific but i have never seen a wiring diagram for the 98 festiva (aspire in the us).
                            cheers. i just bought a tacho on ebay so hopefully i should be getting it next week sometime. expect more questions!
                            1998 Festiva:
                            Motor Sport tacho,
                            More to come!
                              Im keeping an eye on this topic... interesting...
                              I'm here to learn... Teach me
