Does anyone know the part number for an instal kit for grant steering wheels? I checked their web site but they didn't have one listed for the festiva. Just curious if anyone has installed one before and how they did it. Thanks!
Steering wheels
I imagine if you cross reference the mazda rx7 and other mazdas you will find a hub kit. Have to do a lot of things backwards to upgrade these cars. We are no honda civic.1993 GL 5 speed
Try '84 Mazda GLC. That's what the hub for mine is initially for.Ian
25Horseplay is on target! I have a Grant "Challenger 414" steering wheel on my Festy. The adapter for this wheel is indeed the GRT-3597. One very minor caveat... I had to install washers under my adapter "puck" to keep the back of the steering wheel from rubbing on the plastic steering column surround. Be aware that other Grant models might require a different adaptor!
Be prepared for the changes that a smaller diameter wheel causes: the rim now obstructs part of the tach & speedometer and it requires more muscle to turn the car at parking speed. However, at highway speeds, you need to drive the car with your wrists! Subtle angular changes are required at speed!
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
i have a 93 rx7 wheel on!Originally posted by fishnjeeps View PostWhat year mazdas? found nothing for 93' RX7's this may be harder than I thought.
-Aspire brake swap COMPLETE!
