I remember seeing a mod where a rear hatch had a switch to turn the trunk light on, does anyon know from what car that came from?
hatch light
I think some have used the door switches off a festiva, the one's that turn the dome light on/off. Or if you have a hatch latch off a LX you won't need one, I got lucky enough to get a LX hatch
-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
Yes LXs. You can make your own that works just as well though using OEM festiva parts.
Made one using the dome light switch, works great
whoa whoa whoa......where is the write up....did I miss that somewhere? You can't just get away with these flip little statements ,,,,No wayyyyy.....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by GenevaDirt View Postwhoa whoa whoa......where is the write up....did I miss that somewhere? You can't just get away with these flip little statements ,,,,No wayyyyy.....lol
Oldie but goodie
thank you!"FLTG4LIFE" @FINALLEVEL , "PBH"
Sooo... the hatch locking mechanism, the one on the right, with what looks like a wire & a plug sticking out of it? That come off an lx? That's what I should go hunting for?
And is there a default plug in the wiring harness or do I "need" to splice if my car isn't an LX?Mon arme a moi, c'est un stylo.
The latch on the left is the one with the cargo light switch. Some cars have the plug already prewired. I think this is the wire you need to plug the switch into.
Like Brian said, just make one of these and plug it into the same plug where the latch would plug into and you can use the cargo light manually.
There is a ground bolt already near the prewired switch plug, see below
I've noticed the US cars come prewired for a few things that us canadians don't get (like having the wires running through the doors for power mirrors), this could possibly be one of themOriginally posted by 25Horseplay View PostKofkof my 93 was prewired for this latch, so should most cars be prewired also. Yes you want the latch out of a LX.
