my car had a short and fried a wire from the fuse block into the wiring harness. Now i have to remove the dash to trace how far it is messed up. I was just wondering who has had a dash out and how long is it going to take for the R&R. Be realistic, I'm guessing like 3 hours to remove and replace it.
dash removal
I'd highly recommend one of the "swivel head" ratcheting box end 10mm wrenches for that task! The bolts just beneath the windshield, at the L & R corners of the dash, are much easier removed with that tool. Be aware of several screws up under the dash that connect it to internal braces. You'll prob. want to pull the steering wheel off and remove both front seats too. And don't forget to disconnect wires & the cables going to the heater/AC actuators, radio, instruments... 2 people make it a lot easier to wrangle the dash in & out of the car.
I'd allot longer than 3 hrs unless you've done the operation before. Plus you've gotta find & fix the damaged wires/connectors.
Hey! Don't forget to take some detailed photos!!Last edited by sam.1956; 01-20-2009, 07:16 PM.
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
Good thing is the Festy dash doesn't weigh very much and I'd bet isn't anywhere near as complicated underneath as some you've had to deal with. Hmmm.... 3hrs is prob do-able then! Go for it!
Sam, I don't recall you taking your dash out.1992 Green GL - "It's not easy being green" - Kermit - RIP killed by a tree
1992 Aqua Funtop - Belle
Wife of V8Festiva.
Madness Committee Member
website www.festivamadness.com
Get a wrench that ratchets... 10mm for the top 2 bolts in the dash. Ford (or Kia) installed the dash with the windshield out, so it was easy for them... It's nearly impossible without the right set of tools.
I've pulled a dash, and reinstalled one in less than 90 minutes... However, it was the 5th dash I've pulled from the Festiva... So, I'm getting better with time.
Why do you need to pull the dash to get to the wiring harness? Remove the 2 screws that are holding the fuse box in place and it will put out from the back of the dash (with enough twisting, pulling, etc)... You'll be able to drop the fuse box down into the footwell area and trace the wire from there.
If you don't have to pull the dash, I wouldn't. Putting it back in, hooking up the heater tubes and stuff, all a pain.
Good luck!Simon - pimptiva.com
To remove the two bolts on top of the dash you are going to need some really short sockets if you intend to get a rachet on them. I used a cheap six point box end wrench and custom bent it in a vise. Ive also used a short socket with the vise grips clamped on them. Watch your windsheild. One of the toughest things I encountered was reconnecting the vent ducting after getting the dash back in.
It takes me five minutes to get the gauge cluster bezel off.Originally posted by festivaWES View Posti can take out mine and reinstall it in 5 minutes!!
^^^ I'm a Fat Boy!!! Smedley -- I've pulled a couple of dashes out for V8Festiva. I'm his indentured servant with a wrench! HA!
i already pulled the fuse box and it is fried for at least a foot back. im just tired of reaching my arm around up there and figured on pulling the dashOriginally posted by SimonTuffGuy View PostGet a wrench that ratchets... 10mm for the top 2 bolts in the dash. Ford (or Kia) installed the dash with the windshield out, so it was easy for them... It's nearly impossible without the right set of tools.
Good luck!
What wire did you fry... And how? If you know where that wire goes, you could just install a new wire and run it to wherever it goes... For example, if you fried the 12+V radio wire, splice a new wire at the fuse box, run it to the radio and cut out the old piece leaving it "in place", since there won't be any power to that old wire anyways.
As said above... Be careful of your windshield... I ended up cracking mine the first time I pulled my dash out. I'm a little more careful now.
so beside the 2 top-of-the-dash 10mm bolts, what other bolts are hard to get to?
-Aspire brake swap COMPLETE!
