So... I've heard this question asked before... People wanting to remove the bottom section from the hood, mount it to the fiberglass GTX hood and then you'd have something that's structurally sound vs. the flimsy fiberglass copy.
Here are my thoughts... It would work! However, you're going to have one heck of a time getting it out in 1 piece, not bent, and an even harder time mounting it to the fiberglass hood.
My scenario is that... I sold my fiberglass hood with the bodykit to Dean last year... Since the car was parked, I didn't need a hood. Since winter will be over soon, I decided to start working on a replacement. I still want to use hood pins though instead of going with the latch and hinges. So I started cutting away the unside of the hood to make it easier to mount on the pins.
Without the "subframe" of the hood... The metal hood is actually pretty light. But, it's also REALLY flimsy! It moves and bends every which way... In fact, it might be as bad as the fiberglass hood in shaking. I still have a bit of cutting to do until I'm ready to mount it... But I'm getting close.
I'll toss up some pictures later. Unless it's an epic fail, and then I'll scrap the hood, find another one and just use hinges instead! :-P
