I've got a 1990 Festiva that the ignition cyl won't turn anymore. Instead of replacing it, has anyone wired in a push button start to their car? I'm not looking for anything fancy, but a simple setup.
1990 L - Push button Start?
Yeah I did it once about twenty-eight years ago.It was a 73 Midget. Piece of cake, and I was just a no nothin' 21 yo kid. I got a push button from Radio Shak and put it in a hole where a light was that came on when my first wife killed the engine on 50% of starts.88 Festiva 5 speed
89 Automatic L with 1 1/4 hitch
93 parts car(not much left)
89 free parts car 5 speed
03 F150 6 cyl 5 speed
05 Accord 4 cyl 5 speed
"When you've got kids, That's all you've got."
Yes, do a search, I'm sure there's something there. Very easy to hook up. I have one on mine, but just for fun really. But...you say that your ignition cylinder doesn't turn anymore..is your steering wheel in the "locked" position then? What position is it in? (lock, acc, on, start)
Ok, thanks. I'll check it out online and see what i can find. I wasn't sure if there was a member who had done this to their car and knew the right way to get it all set up.
The ignition cyl is in "lock" and when I try to use the key that used to work in it, it doesn't turn at all even with lube and jiggling, pushing & pulling. I then pulled the pass lock cyl and took the code to a locksmith and had them make me a key. That one does the same thing.Chad
1990 Tiva L - Yellow
1995 Metro - SOLD...
2002 F150 FX4 - Black
1966 Galaxie 500XL - Black
Ok, so if I understand, your steering wheel is in the "locked" position.
How is installing a push-button ignition going to help? How are you going to steer, etc?
And for that matter how will you get the car to start at all if the key cannot be turned to the "run" position?
Or am I missing something here?
I lost the keys to the car. A friend had an old festiva and gave me his key. It worked in the doors and ignition cyl as it turned all of them.
The car sat in my garage for 2 mo and I tried to start it with the key my friend gave me and it would not turn at all. Then I was turning the steering wheel and now that is locked. I went and got a new key made at the locksmith and that won't work either.Chad
Are you turning the steering wheel while you try to start it? If the wheel is locked you probably need to put some force on it to get it unlocked with the key in the ignition"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
quaddawg has one on his machine......
-Aspire brake swap COMPLETE!
Might be a lot easier to post a want ad here and buy an ignition swith with a key. By the time you buy all the parts and do the work you could have simply changed it out.
Lane has a good point. Could be something as simple as wheels cut left or right and placing side pressure on lock.That is if key worked before. Could be having a senior moment. I had to bail my mom out once,drove across town to pull hard on steering wheel to get key to work.88 Festiva 5 speed
Yeah! That's what I was trying to say, it just didn't quite come out rightOriginally posted by Handyman View PostLane has a good point. Could be something as simple as wheels cut left or right and placing side pressure on lock.That is if key worked before. Could be having a senior moment. I had to bail my mom out once,drove across town to pull hard on steering wheel to get key to work."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
