Is this link useful for anyone?
Lighting
looks like both festiva and aspires...if those crystal clear lamps with fit on a us festiva then i'd like a set of those, then i wouldn't have to hand make a clear cover when i do the bi xenon conversion.Jesus is on my dashboard, But the Devil is under my hood
1988 ford festiva...in limbo, apartments suck
1995 Ford Aspire...in limbo, wow i need a garage
2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
There 2 here look similar to the headlights I got from FMS with the one piece grill.
These corner lights look like the stock ones however, which would not fit with the 1 piece grill (see the black outline on them?) - That means that you would need to custom fabricate a grill or find a Kia Pride one (not one piece) to use with those headlights... The clear corners, or even the corners with the turn signal "nipple" on it would should work with the stock Festiva headlights.
The tail lights are awesome. Even the non-flat ones like I have, the indents go IN and not out like the US-spec ones. I picked a set up from the Phillipines, except they came to me all shitted up (cracks and faded really bad)
Both of these look great, except I would check to see if the headlight is plastic or glass. There is a contact there, but the company is in China, so I don't know that you would get any type of readable response.Simon - pimptiva.com
my guess would be that they are plastic, usually use those metal clips with the plastic ones....just order 2 sets in case they oxidise fast or get some gts headlight covers... as long as they don't yellow then plastic isn't a problem, just sand em down with wet paper and buff em out to look like new. those tail lights are awesome! i wanna set of those too.Jesus is on my dashboard, But the Devil is under my hood
