How to install LEDs in your gauge cluster
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Looks like mechanicaldj is building a sticky with parts of the wiring diagrams.Originally posted by ejp2fast View Posti only have the Haynes wiring diagrams... how do i obtain a copy of the real deal?
Works fine because those leads are tied to the PWM dimmer switch, as FB71 has pointed out above.Originally posted by ejp2fast View Posthotfordcat did this LED mod and said that the 2 leads in the back of the cluster worked no problem with his.. so thats what i did.'93 Blue 5spd 230K(down for clutch and overall maintanence)
THanks for the pic Fetiva tunner!
Nice!
here is my picture. I am using the diffuser plate, and as you can see it it concentrated in the center... i did have the diffuser plate totally off first, but that was way too bright..
-Aspire brake swap COMPLETE!
