Hi all,
I have designed some new gauge faces for my non-tach cluster ('88 L+) and have some questions.
I searched and did not find exact answers and have not worked on a cluster before.
1). I cannot find a definitive answer on whether or not the gauge needles (gas,speedo,temp) can be removed or how to do it. If I can't remove the needles, I don't see how I can install new faces. Do you need some kind of really small puller of some kind or can you just give 'em a good pull and they come out? Any hints are appreciated.
2). On either side of the needles there are two small screws. These are for....what? Do they hold the OEM gauge faces on? Do I need to remove them?
3). I see that the bulbs that light the cluster have little white rubber sleeves on them; do these do anything? Has anyone else seen these? I have something like that in my tach, but the sleeve is blue to make the light blue. Why in the world are these white, since the inside of the lamp assembly is white?
Thanks everyone!!
Mark
Thanks everyone!!
Mark
