instument cluster
    Send the seller an email and ask him for some measurements. Thats what Id do.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      Looks like a mercury tracer style (mazda 323). Probably won't fit without modification but it will probably be easier to fit than the digital dash from the 626 that others have successfully installed.
      I'm going to come at you like a spider monkey!
      White 1993 L plus, 5 speed - 47k miles
      * Aspire brake swap, 14" Miata wheels & Tein coliover suspension
        Yeah I was thinking early Protege(could be mistaken).
        - Unknown
        - Quentin Crisp
        - Bumper Sticker
          Hi there.
          Hi there.The dimensions of the cluster are 305mm wide and 110mm in height.Thanks regards Barry.
          The Festiva cluster is only 287mm wide
            Since this cluster is 18mm too wide, I am going to have to have a custom housing 3D printed for the components inside my digital cluster. Lots of big talk. I haven't opened it up yet to see how large the circuit board is.
            I have five non-tach clusters to sacrifice for the sake of science.
            Thread 13093
            YouTube
            sloppymechanics
              Isn't that first one just like the 323 gt cluster that some have swapped in? I have one without the tack I was always gunna put it in but wanted a white one.
                I see that it's for a 2004-2005 car. So the speedo is probably electronic, therefore not compatible.
                  Viva Portugal. I wonder if this Audi TT cluster is small enough to fit our Festivas?
                  I can do some pretty neat stuff.
                    Hey bravekozak there is an answer to mechanical speedometer
                    It fits i just need to figure out how to drop the voltage and retain the signal then read it with my arduino. It is probably simple but im a noob and haven't dedicated much time.
                      Very interesting. I think I'll buy one because it's inexpensive.
                      The thread is imperial. That is correct.
                      I need to find out what kind of connector it uses.
                      Thanks.
                        It connects. I have one. I used tiny female audio spade connectors. If you find the right connector let me know!
                          It looks like a stock Hyunda engine wire harness connector should fit. I cut a couple off at the junkyard yesterday.
                          I will keep you posted.
