Hello!
Well now that my Festiva is less then 50% Festiva I've been looking to see if there is anything else I could change. I walking around the local pull-a-part, as I normally am doing on my day off, I passed a BMW a light went on (or off?) in my head...
Long story short this is a quick test fit to see what it would look like on a Festiva!
There is not much wiring nor cutting to be done, the front ends are almost the same size, the same height and both are kind of flat.
What do you guys think.... should I continue ??
Poverty produces creativity
