I bought this system from member Tim several years ago and am finally getting around to installing it. I've have several questions about what I've got and where it goes.
Here is a pic of the dryer and compressor. I'm trying to figure out where the hoses for the "A" and "B" connections would go. Do they attach to the compressor or to the condensor?
There are two connection points on the condensor unit. What do they attach to? The "B" connection had a little plastic cover on it, so i'm not sure if it connects to anything.
This is a pic of the interior switch. What is this single plug"?" ? The other plug attaches to another molex plug. So i know where that goes.
Any idea what this mystery bracket is for?
A pic of the engine block through the grille. I'm assuming this is where i bolt of the pulley bracket? Anyone know if this has to be tapped? If not, anyone know what size bolt it uses?
Here's the complete setup:
Tim said that there are no hardlines and that its basically just two hoses to connect this system up. Much simpler than the OEM system.
Any help would be appreciated. Thanks!
