Hi, well tomorrow i am going to go pick up everything i need to paint my car and have some questions.
-What kind of mixing ratios should i use? (ex, paint, hardener, reducer, catalyst)
-what is a good gun and how many do you need (i heard 1 for paint/clear and another for primer because its thicker)
-this is what i was thinking for painting (correct me if i am wrong)
2 part epoxy primer (one coat)
high build sandable primer (two coats)
black base coat (one coat) (around windows, going for lx look)
blue top coat (two coats)
slow drying clear (3+ coats)
hardener and reducer (i have no idea how much)
Also other things i think i need
-a small flexible foam block (for wet paint sanding)
-air compressor filter
-tape and paper
Is there anything that i missed?
I know these are alot of questions but any help would be very much appreciated.
Thanks in advance!
-tape and paper
Thanks in advance!
