Dash clock ?'s
  • Dash clock ?'s
    The dash clock that some of you have (from a 121 I think)..... is that a plug and play or did you have to run power to it?
    There is a set of wires SOMEWHERE, but nobody has been able to find anything.
    You would first need the wiring diagram, because if you give power and ground it wrong, you'll blow the chip up and it's a waste of a clock.
    My ideas for the clock are much like the radio; constant power, ignition, lights and ground.
    Simon
    Simon - pimptiva.com
      I blew mine
      I Blew my clock up....well I think I did, I didn't open it up to see if there was a burn mark on it before I started messing with it....but I probably did anyways....now to try to locate another one....
      Shaun
        I found that the clock from a Tracer does fit the Festiva. The screw holes line up, and the wiring harness from the Tracer can be hooked up to the Festiva to provide power to the clock. The only problem I ran into was that I know of no covers that fit the Festiva clock area (you could cut out the blank one that come with the car...).
        White '89L auto - Sold!
        Silver '06 Rav4, 95k!
