So I got an orange number gauge cluster with tach for my 92 GL and the tach is not working. From a couple searches I found that there should be a yellow/green wire that goes from the cluster to the negative side of the ignition coil. My car, although it doesn't have a heated rear window, has the wiring for the rear defroster switch at the dash. Looking under the hood, there are a yellow/green wire connected to the coil and one unplugged and with nowhere to plug it. Look at these photos:
This is the plug with the wire connected to the coil:
And this is the one just next to the coil:
Is that loose yellow/green wire with the small plug the one that needs to go to the negative side of the coil? And which is the negative side of the coil?? Any help would be greatly appreciated. Thanks
