Hey, I noticed how close the 88 Festiva I have and the 88 323 SE are and I was wondering if the dash cluster from the 323 would fit the Festiva? I would do whatever necessary wiring was different if any... I really want a dash cluster that displays more than 85mph, 'cause at some point I'd like my car to be able to do it.
88 323 Tach cluster
88 323 Tach cluster
Tags: None
it actually takes more work then you'd think to swap the 323 cluster is, it mounts very differently, the cluster uses 3 connectors as compared to 2 in the festiva, but it is possible
