circlip install
I cut the Festiva visor mount with a utility knife, down to where the Mini arm groove was visible. I only had some 7mm circlips. The circlip would have to be streched to .330" which was too much. I will change up to a bigger circlip tomorrow. The circlip keeps the visor in place an snug.
The proper steps for modification are:
1) tilt the vise to the proper angle to end mill a 1/2" recess
2) ream the hole with a #6 taper pin reamer
3) then ream only to about 1" up a #7 taper pin reamer
4) cut the visor mount stem down with a utility knife
5) install a 5/16" circlip
It looks stock and works great!
Now, I just have to install some connectors and pull a couple of wires across from visor hole to visor hole and then down the A-pillar
