How hard would this be to do ?/
  • How hard would this be to do ?/
    I got this pic from a 121 or Pride,forget whcih.Anyway,if you se the side panel by the seats.I would like to copy this with mine.Anyone ever done this ? How ?? I have the extra material,but,not sure how to go about it .
    Just cut the material and glue it with 3M upolhserty glue.
    '90 LX
      I saw a write-up/partial write up on here about this. Whoever it was drilled holes in the panels and were planning on covering a custom fit panel to install in that spot. I'll try to find it for ya
        back the material with 1/8 foam and then glue it in and use a matching piping to border it. no sense in doing it if you're not going to do it well...
          Here it is...it was festivatunner
          Discuss enhancing your Festiva or Aspire interior and exterior (including custom paint, bodywork, seats, etc)
            You certainly could do that Tony with left over door panel clips like shown above. I would use 3M 08090 Super Trim Adhesive in a spray can, spraying a light coat on the material, and backing board like a door panel has. Let both surfaces dry slightly as the instructions show you on the can, then lay the two together from the center out with the fabric folded in two lengthwise to make it easier to handle making sure not to trap air in between the two. It will bond together like contact cement using it this way, so when the two make contact, make sure you are where you need to be. You can also draw a couple of lines on both surfaces as reference points. Biggest thing, if you are going to do it in a pattern like that Sport material has on it would be to make sure the geometric pattern looks right as layed out. Test it out inside the car by taping it on, and stand back and look at it first before gluing it down.
            Michael
            Have owned 9 so far
              Tony-
              The 121 actually has the vinyl glued directly to the panel, but I wanted something removable so I could change it if I so decided.
              It was prety simple - took an made a patern of the area and transfered it to a 2mm pvc board. Took an extra set of panel clips and cut the holes - then all I did was took backed vinyl an used 3M adhesive to glue it to the pvc board - unfortuneately I dont have any pictures of the finished product because I never got to install then due to my seperation. All in all the hardest part was making the template.
              92 GL - parts car
              97 aspire - parts car
              87 323 DX - daily driver
                just buy them
                Go on ebay.com.au and have them sea mail the whole interior to you. It takes about 3 months to arrive. But it's about 1/6 the cost.
                have him send the door panels, wheel well covers and fun top at the same time. Then there is no way you can ever lose the Festiva of the month award. I'll even chip in a couple of hundred dollars for some other parts from this car. Ask the seller if would consider parting it out.
