Yep, I found one. Now I'm trying to get it installed in my Festy. I know it can be done. Gro Harlem has it done to his. Does it just bolt on? It's cold and I don't want to buy a steering wheel puller if I don't have to.
MX-3 GS SE Leather Steering Wheel
It can be done. As far as removal of your current steering wheel goes, pop off the little square Ford logo, partially undo the big nut in the middle the wiggle, pull and wiggle and pull some more. It will come off with a little effort. When it lets go you will know why you left the nut on! It helps too if you change your hand position as you wiggle and pull.
Once the wheel has released from the shaft, make a note of its position relative to the steering shaft, remove the nut completely and pull off the steering wheel.
I don't know if you have to make any changes to the MX-3 wheel but installation should be just the reverse of installation.
Good luck,
Ian
92 GL Sport
CalgaryIan
Bah, don't be a wuss... Remove the nut and then grab both sides of the wheel and just start pulling from side to side. It'll come off, and I've removed my wheel at least 30 times, and removed countless numbers of wheels from junkyard cars without EVER coming close to hitting myself.
Simon - pimptiva.com
Simon, me too. Take the nut off. Grab the wheel on the sides with both hands, pull on one side and push on the other, and then reverse. If it is not loose, move your hands to the top and bottom and do the same thing. They pop off without a wheel puller. I've used a wheel puller but I tend to bend the bolts on those so I quit.The Festiva Store
I don't see any reason why they would be different. I believe Mazda used the same spline for all the older cars. I got a leather sterring wheel out of a protege DX and it fit in just fine.The Festiva Store
it fits perfectly & its easier tahn hell to install.
The hub is 21mm. Unscrew the 3 10mm screws (or use a philips) and pop off the center cover. Loosen the 21mm and remove it. Then grab the wheel at 9 and 3 o'clock and wiggle it firmly but not violently back and forth. After a little while (even if it seems like it isn't coming loose) it'll beging to have play side-to-side. Keep doing it and it'll wiggle off.
Installing it is pretty much reverse of removing it. Just throw it onto your festiva, hopefully you'll get it straight since therea re lik 32 positions you can put it in. Then tighten the nut and it'll secure into place.
The horn should work too, just attach the lil spade terminal to ur existing hornpad thing and it'll work good
Wil
02' Sc00by WRX Sedan (current project)
00' Celica GT Automatic 38mpg gas-sipper (sold)
05' Scion xB box-on-wheels (sold)
93' MX-3 Hybrid on LSD (sold
96' Slowtegé 42mpg Beast-mobile (engine exploded)
93' B6-ZE 'tiva GL aka"Blue Bomber"(now owned by darpien)
Oh yeah, that's a nice looking wheel.
I need to do some winter 'yard tripping myself.
good find aaron! im thinking about trekking out into our cold minnesota weather as well to fit up the escort gt wheel with cruise on it into my festy :wink:
since ive got the bp too im pretty sure the cruise control shouldnt take too much to rig up :twisted: it would sure as heck be nice for long trips and look completely stock... you guys can go mazda all the way, im keeping my ford badging and staying low
sleepers rock my world Yo!
1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
