Ok bought a map light from euro witch is great shape, but i went to install it and it don't look like it will fit right. I did read the thread that wcbarker did. I seem to not be able to get it to sit right. It seems like there is part of the roof is in the way. Is this just because of the head liner? I have not cut it just yet was trying to mock it up and are having troubles.
escort map light
It should fit just fine. Put one in my 88 L. All the screw holes are there, even though the festy light uses less screws. The Escort connector is a little bigger, but just tuck it in and it will be fine. Also if you hook it up and it doesn't work right, switch the wires and it will. If you do a search, there is a write up on the correct wire connection.Dan
So all three screw holes are already in the roof of the festiva?Originally posted by drddan View PostIt should fit just fine. Put one in my 88 L. All the screw holes are there, even though the festy light uses less screws. The Escort connector is a little bigger, but just tuck it in and it will be fine. Also if you hook it up and it doesn't work right, switch the wires and it will. If you do a search, there is a write up on the correct wire connection.Man should eat when he can for Man does not know when his last meal will be.
Yes all 3 screw holes are there. On mine I had to cut a small section of the headliner to get it to fit. Where the map lights are sticks up above the headliner so I had to cut a (approimate measurements, use a tape to measure before cutting) 1 1/2" X 3" hole on the opposite side of the crossmember (the middle screw connects into it). Fits like a glove.
:festiva::newb::festiva:
Yup just cut the headliner back a little. Neanderpaul also did a write up with pics.-Greg
Redneck Engineer
FOTY - '09
exactly
Here is a pic showing the minimum you would have to cut the headliner to make it fit.
Notice how the other screw hole is hiding.
You will have to punch two holes and cut a rectangle where the new lights are.Last edited by bravekozak; 01-28-2010, 09:23 PM.
