My rear defroster looks like it should work, it is intact and in good shape, the light comes on on the dash but it does not heat up. So if you got one out of a scrap yard it still might not work.
Rear Window and Mirrors
My 89 L had the wires for the power mirrors under the dash on both sides but you will need the harness wires that go in the doors.Originally posted by needragr View PostBummer! I just scored from the JY a set of PW mirrors, short pigtails & switch from a 88LX hoping I could slap them on my 89L but now I come to learn my car has no harness from doors to dash/switch?
Am I going to run into the same thing with the cargo light, R. wiper/washer (pump) defrost hatch?
Can you go back and take them out of the LX? It's not hard at all to put them in the door. I even added a harness in the doors that included wires for power windows.
The blue wire for the cargo light ground was alread in my hatch and the wires for the defogger (it has the defogger wires on the window). Not sure about the wiper.
Do you know about using a mercury switch in the hatch instead of changing the hatch lock to make the cargo light work?Last edited by 1990new; 09-19-2014, 08:37 AM.
I revisited the installation of those Pwr mirrors the WE and sure enough... NO provision to plug in the Pwr mirrors under my dash! So I guess I have to manually wire it.
1st Q: where should I pull switched prw. from ? 2nd Q: the toggle rocker switch has got to be oriented correctly in the dash socket, how do you tell what side is is up vs down? Last Q: (for now) anyone have any of the correct gauge wire & color combo from an old harness lying about....Last edited by needragr; 05-18-2015, 10:54 AM.
power for cig lighter, mirror sw, and radio come off the 15A cigar fuse. the big sheet wiring schematics will give you colors and guage of wire. i thought someone sticky'd a set. unfortunately, the switch connector (212) is shown both ways in an EVTM so you might just have to experiment.
