$25 New Carpet Install
  • $25 New Carpet Install
    *I take no responsibility for your injuries if you screw this up and hurt yourself, do this mod at your own risk*
    When i bought my Festiva, the carpet was nasty, and had a bunch of holes in it, as whenever the previous owner had something to fix under the carpet he just took a knife to it to get it out of the way, but that's whet you get in a $500 car. I wanted to get some nice new carpet to put in, but was unwilling to pay the $150 that the folks on ebay wanted for a new carpet. So i decided to do an expierement to see if i could mold my own carpet into the Festiva. The results were surprisingly good! Instructions are as follows.
    Tools and Supplies Required:
    Socket set (really only need 10mm and 14mm), ratchets, extensions,
    Phillips Screwdriver
    Razor knife, with plenty of replacement blades (it will Dull Quick)
    Scissors
    Needle nose pliers (the smaller kind with the curved tip)
    Punch (needs to be a sharp one, i used an old broken screwdriver that i ground the shaft into a point)
    Double Stick Carpet tape
    6'*8' Area Rug (needs to have a very flexible backing, not a stiff plastic one)
    3'*5' Smaller rug (matches the other rug, this is for in the hatch)
    I got the large rug for $16 and the smaller one for $9 at a store called Ollie's Bargain Outlet, Look for them at your usual discount store. Everything else i had laying around the house.
    The Procedure:
    *Note, this is a good time to do the Escort console Mod if you have been thinking about it, or any mod to your interior for that matter*
    Start by removing the seats, your interior should look like this:
    Then continue to remove the seatbelts, seatbelt controller, console, under dash box, and supporting bracket attached to the floor, and the trim along the bottom of the doors.
    Finally, remove the carpet, You should look like this now:
    You need to take the padding off the back of the carpet, and also make sure to get the white plastic clips that held the carpet down at the doors.
    Put the padding back in it's proper places and secure it with the carpet tape.
    Get you new carpet, and start by cutting a X in the middle of it for the gear shift and the E-Brake, then lay it over those parts. Start under the dash on the drivers side, laying and smoothing the carpet, tacking it down with carpet tape when necessary. make sure to keep it smooth so it won't get caught in the pedals. As you get to a place where something bolted it, pull the carpet smooth up to that point, use the punch and razor knife to make a hole, and bolt down the part over it. Try to place bunches in the carpet under things where you cant see it, like under the seats or console.
    I did the drivers side first and then the passengers side, using the plastic clips under the doors to hold it in place there as the original was. Make sure to pull everything tight and put any lumps where they will not be noticed/ dangerous.
    Finally tuck the carpet in slots in the back under the trim for a neat finished appearance.
    Congrats, your car now has nice new carpet! Enjoy!
    Nice writeup, thanks!
      Looks very good!
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        Totally getting fake green astroturf from Lowes to do this.
          nice... beginning to reconsider placing a black carpet
          if I write badly....thanks google translator
            that looks good - have you done upolstry before?
            92 GL - parts car
            97 aspire - parts car
            87 323 DX - daily driver
              I have not done a whole lot, but I have been doing some upholstery on the Edsel I own, but am yet to do the carpet.
                sweet my carpets lookin a lil nasty. ive been lookin on ebay for a replacement but your right, 150 is way too much. didnt think to look at ollies...that place is the greatest!! lol. thanks for the write up!! vote to be stickied!!
                btw, think you could get a pic of the final product?? with the seats and what not put back together. kinda interested as to what the final product looks like with everything put back together
                  Looks good, definitely worth the savings.
                  '90 LX
                    As per request, here are some pics of the finished product, complete with console from a 1995 Escort. (i was going to add these to the end of the first post, but for some reason it wont let me edit )
                    The Front seats, and console. Sorry it is a little blurry.
                    The back in the hatch:
                    The Back Seat:
                    And the top view of the console:
                      WOW!! looks alot better. oh btw i literally just got back from ollies with a roll of the carpet..hehe. ill post up before and after pics when im done if anybody would like to see em??
                        Looking forward to seeing them!
