Does any one know if the window regulators out of a 323 work on a festiva the reason I ask is because I picked up a 323 to do a b6 swap and I noticed how smooth that the windows rolled up and down and I know that many parts will inter change I didn't know if this is one
Window ?
You can adjust your currently installed regulators so they travel up and down more easily. Loosen the nuts that hold the regulator to the door frame and roll the window up and down to see where the position of the regulator should be for easy operation. If it's too far off for the window to travel without binding on the weather stripping, it'll be tough to move.-Zack
all of my Festivas have the same problem when rolling them up they fall forward and I have to use my other hand to hold the top of the window back into the track I was just assuming that it was the regulator I was unaware that they were adjustableJustin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
