CAD Projectors
  • CAD Projectors
    Im thinking about dusting off my old CAD skills and create a cad drawing of a set of HID projector light housings and hopefully get a final vacuum formed version for my 93 festy. If anyone would like to share some information go nuts. Need all the information i can get.
    93 Ford Festiva WA (project car)
    98 Ford Festiva WF (aspire)(parts car)
    98 "Gloria" Toyota Corolla AE101 (daily driver)
    im in for a set, i found a place that said they can make the lens, i think it was 200 for the lenses, sickhids.com
      ok cool, not to sure how i will do it yet, just want to get some plans down. Might draw some and put them up tonight.
        Should be cool, trying myself to get the stuff together to do it; just missing a good Shop-Vac and a set of projectors to do it the old fashioned way....
          Yeah i was thinking about retrofitting in a projector but im a sucker for trying to make my car clean and modern-ish.
            i dont dont think the polycarbonate (?) used in vacuum for is thick enough, i think it would be prone to hazing as well, i think the best bet would be to make a slicone mold and make a good 1/8 resin lens, i bought the stuff to make the silicone mold, but i dont have a vacuum chamber to pull the air out of the mold, so it was a waste of 100 buxs
              Im not too sure how it's done ahhaha all i know is that the place said to me, is give them a cad drawing and they'll reproduce it, i'm happy enough with that ahaha
                I want to put HIDs in, keep me in the loop
                Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
                  GL guys, it's either shelling out for the lenses or changing your whole front end to accept a housing that has what you need already. No one really makes square headlights anymore, but on trucks. My 2006 ranger was a super easy one to retrofit but it's much larger than a festiva light.
                  1993 GL 5 speed
                    i emaiuled sickhids.com last year i think they quoted 100 buxs for lenses and 600 for a completed set with hi lo, and angel eyes. maybe we can get enough people for a group buy?
                      I've retrofitted HIDs myself onto my Grand Marquis.
                      The easiest way would be to cut the fluted lens off and replace it with plexiglass and a protective headlight sticker. The thick, clear sticker keeps it from getting chipped, foggy and damaged.
                      For the projector, there are bolt in H4 projectors that just came out last year. They're bi-xenons so they have Hi and Low beams.
                      $600 is high for a good projector retrofit. Do it yourself with top notch parts and looks for half that. A great start would be to check out hidplanet.com... tons of great info.
                      -Zack
                        Yeah i have done a lot of research on retrofitting and i know i can do it but i thought hey if im going to get lenses made i might as well make a whole new housing. Im currently in the process of moving out for the first time to a whole new area quite some distance away from home so most car activities have stopped till i can get a new job and also uni goes back onto holidays.
                          There are some china projector sets on ebay that go right into a h4/9004/9007 hole whatever you are running thru the front and have their own harness. Out the door you can probably cut costs down in half and output isn't as great as lexus or mercedes oem but its not half as good so its a viable option too.
                          1993 GL 5 speed
                            http://tinyurl.com/4b79xpw
                            A lot of it is kinda tacky but when you make an order you specify 4300k not 6000k rice blue. the prices have also come down a good $50 since i was checking them out 6 months ago
                            1993 GL 5 speed
                              These are not DOT, this may not affect some but others could get a nice tow or inspection.
                              Hella makes DOT housings, not cheap though!
