Been a while since I've had the time and money to work on/race the festy but now I'm back in full force. Got plexi in the side and rear window a new Sparco Sprint 5 seat (never have I felt so planted in, its like I'm a part of the car) and a few pics of my bolt in harness
bar in progress (plan to finish the mock up on Thurs and fully welded on Sat).
Rear Plexi window.
Passenger and Driver's side Plexi windows.
B-Pillar Harness bar mount (uses the lower seat belt mounting hole up top and a pair of
grade 8 bolts with some big fender washers behind them on the bottom).
Main bar running across behind the seat. Also a look at the back of the Sparco.
Plate on the rear shock tower. A tube will run from the main bar in the middle of each seat
and back here (some extra strength for the bar and a big boost in rigidity from the bracing).
THIS IS SPARCO...
Rear Plexi window.
THIS IS SPARCO...
