mesh for a grille
  • mesh for a grille
    well its been a while sense ive been on. im having some luck with the hub as i was talking about in later posts. i got it off im just working on the donator one. its the original nut on the axle so u can imagine a 93 so ya. anyway to the point. i was wondering what a good mesh is to use for a grille. im gonna chop up an 89 grille i got in a jy. Thanks, Cody
    I haven't started looking for myself yet, but I'd try some home improvement type and hardware stores for various types of mesh, especially plastic mesh. Also, search online for more ideas or online stores that may carry that stuff.
    Besides mesh, keep your eye out for other types of grating, fabric, grilles from other cars that can be cut out and adapted. Especially if you can get it FREE from curbside or nearly free from a yard sale (spring's coming!), do so.
    Whatever it is, it should be lightweight and not prone to warping from radiator or summer heat.
      do you guys have tractor supply? or farm and fleet? ace hardware has it but i got mine from tractor supply
      93 festy L "bruiser"
        Gutter Guard screen from home improvement stores.
        Here is some I put on mine:
        Dan
          .... I like that grill, how about another pic or two or three?
          A hunch is creativity trying to tell you something.
            That is an 88 grill, modded, by cutting out the center bar, and fiberglassing up the holes left from the cuts, with a fiberglass body repair kit found at any auto parts store. There are articles on how to do it, in the Articles/Mods section, easily found with the search function. Quite a few peeps have this mod.
            I dont have a lot a pics as I just got a good camera and I just did the grill mod not long ago.
            Dan
              ya i know how to mod it got my 89 grille from a junkyard. went and got some stuff and i seen it layin there and the guy through it in and i do have ace, and i heard gutter mess rusts pretty easy. i want it to look good for a while if u know what i mean
                Gutter guard=$2.50 lowes
                Cut,Fiberglass,bondo,paint,attach with zipties/wire=done....
                With skill it will take(including drying time) 3 hours maybe.,...
                93L sold. First FESTY!
                93GL Sold Too Soon!
                  The mesh wont rust, its aluminum!
                  Thin coat of primer, and a couple coats of "Trim" paint and its good to go. Mine is not bolted in or zip tied. I bent the bottom 1 inch of the mesh 90 degrees (forward towards front of car) made a little cutout on the bottom bend, so it is level with bottom of grill, slid it over the "tab" for the 1 center screw, and slid it over the the tabs at each end. It holds itself in place with the screws on the tabs.
                  Dan
                    thanks, that helps a lot ill post pics when i start to do it. it will have to be after it warms up tho lol as its kinda cold to do it out now
