i need help on re wiring my tach cluster
  • i need help on re wiring my tach cluster
    I bought a cluster metric from a kia pride) and to make a long story short some one told me i need to do some simple rewiring, do you guys with the MPH speedos have to do the same thing? or are the MPH tachs plug and play? i would really appreciate some help on this topic and i have no idea what to do and i want to use my tach. ( i am using the stock guage now) tach-Less
    B6 with lightweight Flywheel, FMS street cam
    Holy heck gee willickers its fast!!drool
    I have done exactly what you are asking about although I did not re-wire my car to get my old cluster to work, what I did was I took a US tach cluster and removed the circuit board and swapped it onto the Kia pride cluster, trust me it will work, then your cluster will plug directly into your factory harness
    And just to let you know, swapping circuit boards is very simple to do
      i should have just went with a mph guage cluster.... though i was told to re pin the wiring from the car,( the little black and white harness)
        The mph clusters still only go to 85 mph though unless you get an overseas one
          so i guess the over seas ones are wired totally different? heh, I am still a little Leary taking the thing over 100km/h
            No problem on the Pride speedo, just install a US board and move the speedo cable to the right. Then it's plug and play.
            Chuck
            91 GL -Ol' Rusty
            93 GL - Lil Red
            91 L - Tweetystiva
              hmm ok, now i have to find a US one now, I suppose i would need a us one with a tach and not just one with a speedo correct?
                ^^yup that's correct, the US tach clusters are fairly common down there and shouldn't be hard to find
