The cowl is an area of high pressure on the outside of most cars because that's where the hood air hits the steeper ramp of the windshield area. The vents are there to take advantage of that high pressure air for the cabin ventilation. If you open that engine compartment panel you may compromise the cabin air and also let in engine compartment hot air and fumes.
I'm not 100% sure on this, but I'm pretty sure. Consult some auto aerodynamic sources to check on it.
Others here may confirm this too.
