so I machined out the original cover so you could see the clock. Still not a 100% happy, my cutter comp was messed up a tad bit. Going to pick up another cover an redo it with my cutter comp correct this time. Easy little mod to do. Had to cut top of clock off, a belt sander worked perfect. There was a step up that needs to be removed so the cover will set flat over the clock. Again easy mod
I KNOW...
I KNOW...
