i resized the pics so give it a few for the changes to go through photobucket
i got my turn signals modified and mounted
i took the stock stylus turn signal and cut the front part off where the lens mounts.
then i cut the outside edge off of the stock festiva turn signal. the cut one is on top
using a small butane torch i melted/plastic welded the festiva bulb portion to the stylus lens portion.
i also had to cut the small top and bottom lip in the far back of the turn signal hole inside the bumper itself. i didnt get any pics of this.
and after 3 tries with my flashers on i finally got a pic with the lights on.
