Rear Drum break
  • Rear Drum break
    Hi,
    I have an unusual problem with my pride '99.
    Right rear drum breaks momentary in the beginning of drive ( some 5km) , I am not able to regulate break force, this is more present if whether cold and humid.
    Drum is ok
    Break plates is ok.
    Adjuster is ok
    If I clean inner surface of drum than in some time is everything ok, please advise.
    Btw – sorry for my bad write, that cause my bad , very bad English.
    Thanks for understanding.
    It may be time to check the return spring on the emergency brake cable within the drum, or, even more likely a brake cylinder piston is seized to some degree. Should that be the case one of the brake shoes will be worn much more than the other. Good luck.
      Check the wear of the pad for evenness. If its uneven, your wheel cylinder is bad. If the pads are fine you need to change the spring in the parking brake arm inside the drum itself. Mine did this a while back, and mine was the wheel cylinder. Hope this helps.
      Fesdiva is it's new name since she's acting crazy- 92 L
        I motion to move to repair help forum. This isnt a customized mod.
          thread move to repair-help x2
