Will one from a 92+ fit a Festiva? I found one for $30 online.
A Protege Short Shifter?
Tags: None
If it was just the ball type, yes. But with the pivot point sleave piece on it it won't fit without moding. The ball and stick portion are the same other than the shape for the stocks. The actual sleave that the plastic cups that hold the ball portion in the Festiva is about 1/8" smaller around than the protege. If you switched out the floor assembly and custom fabbed the solid rod to fit the Festiva it would pop right in.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Thanks a lot! It was a shot in the dark...In love with a MadScientist!:thumbright:
