Clutch Pedal Assembly and Shifting Linkage
  • Clutch Pedal Assembly and Shifting Linkage
    I am in need of shift linkage and a pedal assembly for my auto to manual setup, how much should i anticipate paying for these from a junkyard? Are there any concerns about pulling them from a yard? What should i look for in terms of the best one and which festy to pull them from? (Theres a few of them out there)
    Any and all help will be much appreciated!
    91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
    Adjustable VW MK2 front suspension and Aspire disc brakes
    Aspire rear axle and drum swapped with adjustable KYB rear suspension
    LOOKING FOR RUST FREE SHELL IN CALIFORNIA
    There are quite a few postings here with photos on repairing worn shift lever housings. You could take a look and try to avoid worn ones.
      Well since your not actually looking to repair your clutch/brake pedal, this doesn't belong in the repair section
      soon I'll just start locking threads instead of moving them and let you figure out why
        I'm looking for HELP in regardd of one though
          Ya your asking what to look for, not how to repair it, i don't think it's that hard to figure out what the difference is
