Electric heat would draw a LOT of electricity. I've used one of those HF dash defrosters that cost around $15 or $20 and plug into the cig lighter socket. It barely does the job, slowly!
To heat up the car before starting it would probably drain the battery, so you'd need an extra one or two. I think that's why block heaters run off AC power!
On the other hand, I have thought of this:
An AC heater that you can run an extension cord to from your house or garage. Plug it in with a timer to turn it on an hour before you want to leave in cold weather. The electric heater would be in your car and defrost it in that hour. Before you leave, unplug it and go.
You'd need:
-A heater that fits well into your car, heats up evenly and doesn't get in your way or start a fire.
-Routing the internal cord to a convenient plug.
-Protection for the plug end from the elements as you drive.
-Doing this with a little cover access panel (like the gas cap cover) would be cool!
Zoom, doing this now while you have the car stripped should be relatively easy.
If you park near an electric AC source at work or another destination, you'll have a nice warm car to return to as well!
Even without a heater that works while driving, if your commute is short, you'll stay pretty warm.
Try something like this:
Or this lower wattage one which may be better:
I just used those for examples. You can probably get these cheaper at other places.
Karl
You'd need:
Karl
