I've really been considering this as of late - the incorporation of solar into the electrical system of the Festiva. I have it in mind to install the panel in the roof in the form of a sunroof, with the panel underneath a lexan pane in the shape of a standard sunroof so that I achieve a multitude of things:
A, flexibility of the lexan pane.
B, no UV blockage found in auto glass.
C, flush, clean, and even stock appearance.
D, no direct contact between the UV panel and the Elements and/or road debris.
E, overall longevity of the system.
It is my goal to override (or otherwise assist) the charge going to the battery from the alternator at times when the UV panel receives charge. I'm going for an increase in fuel economy (alternator under load takes ~10hp, no load = ~+10hp, engine works less, gains ~6.3% efficiency? ) I'll need help from all you gurus on this project.
Please keep in mind that progress WILL be slow due to funds and time (I'm in college, and time to be creative is extremely limited).
Any positive input and/or information will be greatly appreciated.
