i want to repair a rust hole and i wonder what color primer to use with a dark green paint? this is a non fancy job and just getting it ready for the winter time and it will cover some bondo
color primer
You probably know this, but body filler isn't really meant to fill a hole. As long as your at it you could just as well cut out and weld in new metal, then smooth with your filler.Mike Holmgren
Thief Rvr Fls, MN
1989 Festiva L, carb. 4 spd.
"If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
