I'm trying to add rear defrost to an 88 L. I have a wiring diagram for a 90 and it shows positive coming from the ignition switch (BK/W), 15A Rear Defrost (BK/W), and to the Rear Defroster Switch. From there, it supplies voltage to the Instrument Panel Indicator Light, Rear Defroster, and Electronic Control Assembly (BK/BL).
I was hoping to take power from the ignition and just run an in-line fuse to the Defroster Switch at BK/W, splice in the BK/BL wire into the dash light, and run it to the hatch.
Can I have rear defrost without my ECM knowing about it? Are the other 2 wires on the Defroster Switch just for interior lighting?
