I saw an old thread about how someone here re-covered their sun visors in black vinyl, and so I decided to give it a try. Turns out it was a tiny bit harder than I imagined to make and sew it the way I wanted to (using the vinyl), so I gave up on that and remade the entire visor instead (except for the metal hinge and frame).
Here are some pics as to how it turned out:
I still have the other one to finish, but I wanted to test fit it to see what it looked like. It feels significantly more solid than the original foam (which was very warped and curved anyway), yet soft because of the headliner+foam fabric.
A small side effect to adding the mirror is that the added weight makes the visor hang down at an angle a little bit since there's no support for it in the middle near the rear-view mirror. I haven't decided yet if it's worth trying to come up with some sort of clip to put above it so that the visor can be supported when up.
What do you guys think?
