You know the shoe box on wheels called the XB? Those headlights resemble festiva lights? How hard would it be to do a conversion?
Scion conversion?
Depends if the are HID bulbs, or regular, if they are high intensity, it means changing all of the wiring to deal with the extra draw on current, if you don't you could catch your car on fire using them.
If they are regular style bulbs its just a matter of a few wires being spliced together. and of course getting them to mount in place, and if they weren't close enough, you would have have alot of space around them, and that doesn't look good.
Logan, but I do like thoughs headlights too :-)
the scion xb headlights are too wide and i believe are shorter than the stock festiva lights.Jesus is on my dashboard, But the Devil is under my hood
1988 ford festiva...in limbo, apartments suck
1995 Ford Aspire...in limbo, wow i need a garage
2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
I never said it would look good, I'm just saying if thats what you want to do, you gotta just do it... no headlight other than another festiva headlight will be a direct swap. sometimes you just gotta start cutting... like I will do if I can ever get my hands on a pair of early '00 Jetta headlights :twisted:No festiva for me ATM...
well what i was planning on doing is buying an xb hood, fenders and bumper cover and cut the headlight curve out of the fender and weld it on a festiva fender and the hood use the first prob 6-8 inches and weld it on a festiva bumper, and the bumper use the top half so the lights line up better and switch out wires here and thereHarley Festiva Dan
