Power Window Install?
  • Power Window Install?
    Tried searching but can't seem to find any threads on power window installs, looking for locally sourced parts that would work in 1988-93 Festiva's that would not require too much modification. Had some issues with my manual windows but seem to have that resolved using amourall but found some really nice side pockets from an early 1990's 626 but trying to install them requires my having power windows. So was hoping to find some threads by anyone who had done the mod. Thanks
    Next time put double quotes around your phrase "power window", otherwise it will search for both words separately instead of together.
    Try thread 16514.
    No local power window regulators. They were standard on Prides sold in Europe.
    Bolt in except for the addition of a relay. Europe had manual seat belts. So you would have to keep the wiring for that.
      Well there ya go! Thanks for the heads up and any other insite would be helpful. Do you know if anyone has tried to mod the manual regulators using power parts from another vehicle such as Mazda?
        I tried to fix the kinked wire by taking the Mazda power regulator apart. You need support fixtures to reinstall covers correctly. I have seen complete regulators sold on eBay Germany for $1. You would only have to deal with the shipping costs. Sea mail would take two months to arrive. It's air mail that hurts.
        You need the door wiring harnesses too. It's not worth the headache to rewire or adapt an MPV, 626 or RX7 door harness. I am writing this assuming you are getting the long Pride door handles with the window switches. Other Mazda switches are slightly larger and don't fit.
          During my keyless entry/remote start install, I prewired my doors for power windows. When I get some time this summer, I'll try exactly what you're suggesting. Hopefully I can find a spare set of Festiva regulators to try it out on, mine work fine as is and that seems to be a rarity.
          The bar napkin plan is to remove the manual winder and transplant the cables into an escort/protege power window motor.
          -Zack
            You will end up in the same situation I am in. That is why I am making new vapor barriers. The primary reason is to plug up that hole where the armstrong winder handle once was.
            I still haven't found the right plug for the card yet. Let me know if you come across something that fills the hole snugly and looks half decent. I really appreciate input from my fellow members.
            In Germany they are called fensterheber.
            The easier install would be to install the switches centrally in the German cubby instead of the door handles.
              Universal set of power windows.
              Works quickly
                Works quickly
                [ATTACH=CONFIG]11949[/ATTACH][ATTACH=CONFIG]11950[/ATTACH][ATTACH=CONFIG]11951[/ATTACH][ATTACH=CONFIG]11952[/ATTACH][ATTACH=CONFIG]11953[/ATTACH]
                Cool!
                -Rafe-
                Things I have for sale.
                Random Festiva Parts
                  I found a universal power window kit similar to cTc's in the latest Mighty Car Mods episode. http://www.rapidelectronics.com.au/p...r-windows.html
                  $125 Australian plus shipping. I haven't check in the US yet but I will report back if I find something.
                  *Edit* BINGO! http://www.ebay.com/itm/UNIVERSAL-2-...c45c6b&vxp=mtr
                  And a links to MCM's video on how to install them. http://www.youtube.com/watch?v=Q1AxO6Bt-kk
                    Once I get my passenger side window fixed, I am so installing one of those.
                      I'm curious what these universal sets look like when the door card is reinstalled.
                      -Rafe-
                        What door card?
                          Um, the door card. I hope you don't have to leave it off with all the metal and power window stuff exposed!
                          -Rafe-
                            I do not believe it will fit back on. Just the vapor barrier and the door handle.
                              Same type of kit I used in a 323 with door cards like ours. No reason it won't fit back on.
                              -Zack
