heads up for you junkyard dawgs. if interested in power locks, keep your eye out for this type mazda actuator. mostly on 90's mazdas. the one pictured here is from a JDM 2 door festiva. it will fit the U.S. festiva with very minor mods. there is even an existing unused eyelet in the U.S. door latch linkage that the actuator rod goes to. you will have to fab a bracket like this one has and also make the correct rod. i will post patterns and dimensions. i hope to have a short how-to pictororial soon. i just have to get the wiring sorted. this is not a fancy system. both locks activate when you push/pull the drivers knob or use the key in the door. the numbers on your junkyard actuator don't have to match this one. as long as it is this style.
