OK.. I'm going to be painting my Festiva, I started prepping everything and I removed the plastic moldings that go across the front fender, doors, and rear quarter. I'm have serious problems removing the rubber like glue that is left on the door. There was strips of double sided adhesive that was no problem. But now I've tried everything on this rubber stuff. GOO GONE, GOOF OFF, sanding, wire wheel, etc... Any suggestions on how to remove this stuff without completely destroying the body? You can see the black strip in the picture.
These damn moldings...
heat gun and something to scrape.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
and wd-40 and a scraping might work.;
'92 Festiva L M/T
'93 Festiva GL A/T
Originally posted by zoe60 View PostLacquer thinner? If all else fails, Xylene has never let me down. bad for you though.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Paying overzealous neighborhood teenagers always works. You said wire wheel so scratching is a non issue I assume. For example I think the last time i ever took purple tint off a car was in the 1990s when i was an overzealous teenagerLast edited by getnpsi; 08-01-2013, 02:59 PM.1993 GL 5 speed
A fresh razor blade and WD-40. Soap and water with the blade works tooLast edited by JPT; 08-01-2013, 03:47 PM.Festiva: Because even my dog can build a Honda.
I used a combination of thinner applied directly to the glue with a rag being careful to avoid the paint. Then a razor to slowly shave it thin as possible. Then a rubber wheel to get the rest. Took me days and days one panel at a time. Ask Sasquatch he helped!
That stuff is exactly the same stuff they use on windshields. It is high modulus polyurethane. Nasty stuff to get off. You almost have to wire wheel it off and then reprime & repaint.Last edited by bravekozak; 08-01-2013, 07:35 PM.
Last edited by Charlie1717; 08-01-2013, 07:40 PM.-------------------------------------------------------------------------------------------
My Musica! Click me!
