Well on my shogun i wanted a new combo sw, plus int. wipers. These things are hard to come by. F3BZ told me to look into this Pride model available on 4green @ 75$ , it was untested yet (if it fits our stuff here)
So here we go:
The Pride SW will fit (plug and play) all the early models that DO NOT have parking and headlamp relays in the car. From my research , the 89 is OK. The problem is that the later models added relays in the car so that smaller current would pass in the combo sw. In the Early festy and Pride models , the SW has relays incorporated in it.
If you want your new pride sw to work with a later model (that has relays) , you will have to modify your harness , remove relays etc. For the later models again , its only the parking lamps and headlamps circuits that needs to be modded. The wipers are plug and play.
The pride sw has the GEN1 stalks (uncurved).
So here we go:
