I have no idea what I'm doing wrong. I've watched youtube videos. I've read howtos. I've even tried all 3 ways I've found to do it. But I've gone through 6 boxes (yes six) of the stuff and can't shrink it to the hatch glass.
I tried focusing on the fingers individually and found something else that says to just go in tiny circles with the heat gun and cover everything. Once i got the top perfect, then ruined the bottom. Then the opposite happened.
What it looks like is happening is that the outer edges are shrinking too much and causing a "ring" around the edge of the glass to pull towards the center and then it looks perfect everywhere but the corners. Try to shrink them some more and it just gets worse. If I don't go that far it still has fingers all along the edge.
I've tried dryer sheets, water, and soap. Dryer sheets seem to be the best. One issue I noticed is that the anchors will NOT stay down on the bottom corners. I'm wondering if maybe I just need to let them float like they want to and assume they'll be OK?
At this point I know I should have just paid someone to do it, but I'm like $90 into it now, and the only place that does it is an hour away, so I may as well keep going for a bit more till I get ticked enough to punch through the window. Not far away, believe me.
Anybody have any clue why I keep screwing it up?
