Thats what I'm working with... any opinions on it would be greatly appreciated. I don't have photoshop, so that is a conglomeration of a scaled picture of my stock cluster and scans of the two guage faces from the guages I bought at the jy. The temp and fuel are stock festy, and the speedo and tach are from a Protege LX (BP car). I chose those cause they fit and I figured wiring the tach might be a little bit easier since its from a B series engine that happens to be the same engine in my car now. I'm thinking I'm going to take that image to the print shop at the college and have them print it out for me on an adhesive transparency, then stick that to a plexiglass face and backlight it. I'm not sure how accurate the speedo will read, but it does plug into the festy speedo cable. On the speedo it says "1025 revolutions per mile"... so if anyone knows the revolutions per mile for a festy speedo that would help a lot. Also, if anyone has a cluster wiring diagram for a tach cluster then I'd love to have a scan of that. Any other thoughts, questions, suggestions or concerns would be greatly appreciated.
Thanks guys
Poverty produces creativity
