I am going to make a heater that will fit inplace of the center shelfs. I will take the shelf insert out and use that room to build an aluminum box. The box will have a computer fan on the backside. A ford f150 heater core will be mounted in the center of the box. The front of the box will have two heater vents on it. I am going to wire the computer fan to three switches that i will mount in place of the ashtry. Each switch will be wired to 12, 9, or 5 volts. The computer fan i will use pushes 252 cfm at 12v but is loud. Flip a switch to get low mid or high fan output. When all said and done the heater should make this winter a bit easier to deal with.
I will make the box from materials i alread have.
The fan will be around 30$
The Heater Core will be 30$
The wiring will be around 20$
Hose and fittings will be around 20$
Total will be around 100$ for a custom heater. I will post pictures along the way and give a review afterwards
