Most members here have removed their door panels at least once or twice. The black butyl tape that holds the flimsy polyethylene vapor barrier can be a real hassle to remove. Has anyone replaced their vapor barriers with a stronger reinforced vapor barrier? One that won't tear when pulled off. Like Cossella-Dorken Delta-Reflex? The aluminized surface reflects inward, so that hot stays hot, and cold stays cold. Nice!
Also, has anyone used a substitute for 1/8 round butyl tape? I am considering using draft sealant. The low-odor clear stuff that you caulk around windows in the fall, and peel off cleanly in the spring.
